[ask] Battery S88
[ask] Battery S88
Postby astrayudha » December 2nd, 2010, 9:12 am
Maaf nih bila saya lancang,
Dulu sih punya login di siemensxp.com, tp kayanya dah tewas :D
Saya punya Benq-Siemens S88 lagi nyari batere sama charger-nya. Lokasi di Bandung, Dulu sempet ada tuh Service Center Benq-Siemens di BEC Bandung, tapi udah jarang liat lagi, ga tau pindah ke mana? atau pindah lantai kali ya..
Terima kasih buat bantuannya
astrayudha
Re: [ask] Battery S88
Postby adhyzip » December 2nd, 2010, 10:39 am
DGE udah ga support lagi ke siemen mas ato benq siemens,coba mas kontak dengan mas threepong,herry poter ato mas gandalf di forum ini..sepertinya mereka ada yg stok tu
Postby Boowin » December 2nd, 2010, 10:56 am
adhyzip wrote:DGE udah ga support lagi ke siemen mas ato benq siemens,coba mas kontak dengan mas threepong,herry poter ato mas gandalf di forum ini..sepertinya mereka ada yg stok tu
iya bener cari mereka aja, mumpung mas threepong lg ada diskon x-mas
Postby astrayudha » December 2nd, 2010, 11:30 am
Saya juga nyari situsnya kebingungan..
oke saya coba cari deh..
tapi mas-mas punya kontaknya ga :D
astrayudha
Postby adhyzip » December 2nd, 2010, 11:34 am
mas treepong ada kontaknya dilapaknya.CEK DIFJB mas
Postby threepong » December 2nd, 2010, 11:50 am
barangnya gak ada ... jangan sms yach buang2 pulsa
threepong
Postby Hendz » December 2nd, 2010, 2:18 pm
ntu si andrew dl jg nyari² jg lom dpt²...sparepart S88 jg
Postby andRa4 » December 2nd, 2010, 4:40 pm
busyet, langsung d-sambut sama mas 3pong. :))
Postby astrayudha » December 2nd, 2010, 5:15 pm
threepong wrote:barangnya gak ada ... jangan sms yach buang2 pulsa
Hehehe. lagian ga punya nomornya mas... :D
Kalo ada PM ya mas.. tapi kalo nanti aku nemu duluan, aku kabari juga..
astrayudha
Postby threepong » December 2nd, 2010, 5:20 pm
cari aja di roxy kayaknya masih banyak yg non ori ....
coba cari lapak sebelah yg jualan batere dsbc ...
threepong
Return to S81/S88
