Tutorial: Un-Locking x65 dan x75 (Manual)
Postby ilham » June 14th, 2011, 1:13 am
POST asli oleh Om Qunto ; Makasih buat PINTURICCHIO buat backupannya ;)
x65 unlocking guide by Kyo Sirowky (saintclaire9@yahoo.com)
Translated & Improved by Qunto!
Alat2 perang yg dipakai dlm praktek ini:
- Kabel data: USB MA-8720P (terpasang pd COM4)
- V_Klay v3.3
- x65 Unlock Kit [by kyo]
** Backup FUBU & EEFULL **
Langkah Kerja:
1. Run file "x65srvMode.exe" (dlm Mode DOS Prompt)
dgn syntax eksekusi: x65srvmode [com number]
contoh:
E:\Siemens Project\x65 UnLock Kit [by Kyo]>x65srvmode 4
Open All Read/Write blocks EEPROM for Siemens x65 GSM telephones.
(c) All people of the Earth and PV`
KEY:
'00000000'
Init COM4 115200 Baud...
Press red button or power to cable....................
Load Service Boot...
Boot Ok!
Error1 Init BFC mode!
* Maka pd layar HP akan muncul tulisan "Service Mode".
>> Pastikan HP anda tetap dlm kondisi Service Mode ini selama proses berikutnya.
2. Run file "Getcode.exe" (dlm Mode DOS Prompt)
dgn syntax eksekusi: getcode [com number]
Contoh:
E:\Siemens Project\x65 UnLock Kit [by Kyo]>getcode 4
Get data for calculation keys for telephones Siemens x55,x65.
x55 Works WIRE(57600..460000), BLUE/IRDA (57600)
x65 Only WIRE 57600.
Init COM4 57600 Baud...
57600 Mode='DEAD'
115200 Mode='BFC'
Set 57600 BFB Mode
SIEMENS Mobile Phones Debugger V 01.00.00
The telephone of model x65
Test max speed BFB mode...
Max speed BFB mode = 57600 Baud
FSN:
F1 C5 D9 B3
Saved in Key.bin
HASH:
FB D1 C5 CA 82 B9 7C C1 C5 90 66 77 CC 67 7E 6F
Saved in Hash.bin
* FSN (saved in key.bin) = PhoneID dari HP anda (tanpa spasi).
** Jika Cara di atas gak jalan dgn pesan error, maka downgrade HP ke versi 25.
3. Run "MAP Maker by CyberGSM.exe" (dlm Mode Windows)
- Masukkan no IMEI and PhoneID anda dan press "Make Map".
- proses ini akan menciptakan file xxxxxxxxxxxx.log (dimana "xxxxxxxxxxxx" adalah no IMEI anda)
4. Run "Freiamap.exe" (dlm Mode DOS Prompt)
dgn syntax eksekusi: Freiamap [xxxxxxxxxxxx.log]
Contoh:
E:\Siemens Project\x65 UnLock Kit [by Kyo]>freiamap 453767806729261.log
map is saved to 'Siemens A50 - 453767806729261 unlock-2005.04.02-10.38.54.MAP'
5. Run V_Klay v3.3 dan apply patch "Open closed EEPRom blocks" :
Utk proses ini, anda harus menyesuaikan tipe patch-nya dgn versi HP & versi firmware masing2.
(contoh berikut utk tipe M65 v25)
;* Open closed EEPROM blocks * M65 v25
13590E4: 00 01
6. Run "eepromtool.exe" (dlm Mode Windows)
* press buttons sesuai dgn urutan yg ditampilkan di "EEPROM-tool-pushsteps.jpg":
Desc:
- Load: open the .map file
- Init: Start communication with your phone
- Select All: Select all blocks on your PC
- Right Arrow: Move all blocks to your Mobile
- Select All: Select all blocks on your Mobile
- Save selected: write blocks to your mobile's EEPROM.
* Press "Exit" when Done.
>> EEPROMtool requires "COMCTL32.OCX"
- Google it, you'll see it, download it and save to your \windows\system32 directory (WinNT, 2K, XP)
7. Be HAPPY, Phone anda sekarang telah UNLOCKED! dan bisa di Hidupkan kembali.. :)
* Alternatif Tutorial: Un-Locking x65 dan x75 (PapuaUtils)
Reason: Update link
Re: Tutorial: Un-Locking x65 dan x75 (Manual)
Postby mamed_3279 » June 14th, 2011, 8:00 am
ini maksudnya unlock phonecode sama kaya di "Tutorial: Un-Locking x65 dan x75 (PapuaUtils)" yah mas? :D
Postby adhyzip » June 14th, 2011, 8:43 am
iyah mas..tapi u kasus yg manual unlock nya..
Postby ilham » June 14th, 2011, 12:00 pm
@Mr.M: Saya hanya uploader saja Mas. Saya sendiri belum pernah pakai yang manual :D .
@Mas Adhy: Thanks atas jawabannya. :)
Postby aziz_gets » June 15th, 2011, 2:06 am
ilham wrote:>> EEPROMtool requires "COMCTL32.OCX"
alternatip jika ga ada library comctl32.ocx
http://avkiev.kiev.ua/Siemens/Soft/OcxCtrl.rar :)
disease,disease,disease my friends
for this whole world's in devil's hand
throw the key or you may die
.:;. keeper of the seven keys .:;.
aziz_gets
Postby ilham » June 15th, 2011, 10:28 am
Yup, download file tersebut dan extract ke folder windows\sytem32. :)
