Elfs: What is and how to install them
Postby ilham » December 23rd, 2010, 12:38 am
Elves: What is and how to install them.
Sumber: http://forum.allsiemens.com/viewtopic.php?t=39076
POST asli: Om Vladimir & Om Dmitry.
Penerjemah: Google Translate.
Tukang edit: Ilham. (rencananya kapan-kapan mau diterjemahkan ke-indo, ada yang mau bantu? :D )
Maaf kalau masih ada sedikit bahasa Rusia yang singgah :P
Q: What are the Elves?
A: The elves - this is one of the possibilities of extending the functionality of the phone, which is performed directly code ARM-processor machines on platforms and SGold NewSGold, ie it is possible to create custom applications that work similarly cimensovskomu software and uses the industry standard ELF (Executable and Linking Format). Hence the name - the elves.
Q: How do I install elfpak 2.3 on my phone?
A: 1. Snachalo pour on the phone folder zbin.
2. Stavim ELFPack + Library
3. Idem in my files, run the required elf, rejoice.
Download all. Elf-files from the directory 0: \ ZBin \ Daemons
Download required. Elf files when you select a file with an arbitrary extension
Processed by ExtD.elf - required in the directory 0: \ ZBin \ Daemons to file 0: \ ZBin \ etc \ extension.cfg. The file format is described in extension.cfg
Mp3 to work should be put AudioHook and Adpcm8-48
Extending the table of registration of file extensions
PIT extension with. Png files
Processed files in the directory 0: \ ZBin \ img named% d.png
To replace the regular image or of the elves - a pointer to a string
with the file name instead of ID (similar to ESI). Images are cached for faster subsequent access.
Program to generate a patch AudioHook AudHookGen v3
And the program to generate a patch Adpcm8-48 x65Adpcm
Q: What is the difference elfpak 2.2 from 2.0?
A: 1. Poyavlenie file swi.blib (File backup and complementary "Big Function Library, for ease of replenishment functions.)
2. Svorachivanie elves when an incoming call with the aid of Xtask 2.0.
3. Grafika 8-bit (On NewSgold - 16-bit)
Q: How do I create a file swi.blib?
A: Option to use ready-made library functions.
1. Open fullflash in Smelter latest version
2. Downloading library from any favorite places
3. menu Smelter: Tools -> Standard objects -> Download the patch library
4. Right-click on the list that appears, Save As blib "
Q: How do I edit extension.cfg?
A: begin extension.cfg preferably those lines:
RUN = 4: \ ZBin \ TED \ TED.elf
SMALL = 4: \ ZBin \ img \ UNK_SMALL.png
BIG = 4: \ ZBin \ img \ UNK_LARGE.png
ALTRUN = 4: \ ZBin \ TED \ TED.elf
this is the first description of the Association of extensions on it indicated what an elf will be opening unknown files. in this slkchae TED.
RUN = - that run
SMALL = - path to the small icon in PNG
BIG = - path to the large icon in PNG
ALTRUN = - what an elf will open when you click Options - Change. It is better to register the same as in RUN =
Next, we describe txt extension
[Txt]
SMALL = 4: \ ZBin \ img \ TXT.png
BIG = 4: \ ZBin \ img \ TXT.png
Here, just to put icons to expand txt, because these files will open as unknown files (ie in this case with TED)
Further, it is desirable to describe bcfg
[Bcfg]
RUN = 4: \ ZBin \ utilities \ CfgEdit.elf
SMALL = 4: \ ZBin \ img \ BCFG.png
BIG = 4: \ ZBin \ img \ BCFG.png
Well, then, describe all the extensions that we need, in any order.
! Please note that at the end of each line nebylo extra spaces because it did may not work.
Example extension.cfg (remove the txt at the end of the file)
Q: What is faster: java-application or an elf?
A: Because the elves are executed directly by the processor without intermediate add-java-type machines, they have access to the whole memory and everything functions of the firmware created by programmers Siemens. Speed of execution of any commands is limited only by CPU power, so it is huge, ten times the speed of execution of java-applications.
Q: Where can I get an elf (*. elf) for my phone and my firmware?
A: Elves do not depend (within a platform) on the model of the device and firmware version.
Q: How do I run an elf (*. elf)?
A: Run the elf made either as a normal application - by pressing the joystick in CardExplorer,
or automatically loaded when power is turned on if the elf is in a directory 0: \ ZBin \ Daemons
Q: What are the folders you want to create for elfpack?
A: You must create the directory structure in accordance to the data archive
Q: How to unload the elves?
A: Upload the elves (who are not demons) is possible only after rebooting the machine, if this operation is not provided in the appendix. To unload a sprite hanging daemon before rebooting the phone it should be removed from the directory ZBin \ Daemons or change the file extension to any other elf.
Q: Established elfpak, trying to run elf Unzip, Unrar and some others, but nothing happens.
A: Some of the elves, such as data does not need to run. To work these elves need to register the association of file extensions with executable elves in file 0: \ ZBin \ etc \ extension.cfg.
Q: Will my elf wizard with a patch?
A: Yes, they are completely compatible.
Q: Explain why you need TED.elf?
A: TED - redektor and text viewer that opens all files unregistered extensions.
Q: How do I replace the graphics png files?
A: After elfpack 2.0 it is possible to replace the phone graphics PNG files.
It needs to know the number of replaceable pictures in the firmware. For each phone model / firmware, they
individual. To find the number of open programs such Smelter. Open your Full Flash, go to the menu list, choose - pictures, or just click on the letter P on the toolbar Smelter. The third column, where the letter N is a decimal number and a picture. On the phone can take advantage of the elves iWatch (Sgold, NewSgold, shmeler multitester (Sgold).
Now rename the PNG image acc. number (for example 521.PNG) and put it in a folder Zbin \ img \ (depending on phone model Zbin folder may be located on disk Data or MMC card), reboot the phone and voila! If Kartika few frames (eg battery, network, dial-up animation, etc.), then just need to rename itself acc. with the numbers in the firmware (in Full Flash).
Q: On my phone is not working / not play / plays only a couple of seconds elf mp3 player. What's wrong?
A: For mp3 to followingManufacture:
1. Elfpak (for each model / firmware individual, preferably at least version 2.0)
2. Audio Hook patch (for each model / firmware is different, generated by the program AudioHookGen v3)
3. For new players, and even patch All ADPCM able to reproduce on x65 wav adpcm with sampling 8000-48000 Hz.
(For each model / firmware is different, generated by the program x65Adpcm)
4. Sam elf mp3 player (several versions, so that each vyberaem yourself one that fits him best)
So when you click on the mp3 ringtone will play it, add in Zbin \ etc \ extension.cfg example the following lines (for elfpack 2.0 and above):
[Mp3]
RUN = 0: \ Zbin \ mp3 \ mp3player.elf (the way to the player)
BIG = 0: \ Zbin \ img \ mp3_big.png (path to the large icon)
SMALL = 0: \ Zbin \ img \ mp3_small.png (the path to a small icon)
Q: What is the *. bcfg files? What are they for? Or that the elf CfgEdit, what is it for?
A: The *. bcfg files store settings elves. Elf CfgEdit needed it for editing *. bcfg files. To use an elf
it is sufficient to prescribe an association extension.cfg expansion bcfg files with the elf and then edit just klatsnuv to *. bcfg the file of one or innogo elf.
Q: I have edited extension.cfg, added expansion bcfg, klatsat the file - still nothing!
A: After each change extension.cfg need to restart the phone.
Q: Why when you start some new elves off the phone with a distinctive zvkom rush?
A:
1. Probably should update the library functions. Probably should update the library functions. Look here or here for my phone model / firmware version.
2. Elf is not under your platform phone.
Q: Why when you start Naticq climbs error "dnr error 221!"
A: It is necessary to folder Zbin \ Daemons put an elf GPRSD.elf
Q: installing a new version elfpack and when you turn pickoff
A: The new version elfpack is desirable to put on a clean fullflash, because the new version in some cases may conflict with already installed patches.
Q: I noticed that some elves changed the weight on the X kb, frequent pikoffy, displays strange messages, etc. etc. What is it?
A: Maybe a virus. With the advent of the elves was possible raspotranenie elf-viruses that can harm your phone / other elves.
Out - check the program [urlhttp://allsiemens.com/soft/flashers/Smelter.rar]Smelter[/url] elves viruses (Smeltere opening Full Flash> Tools> Elf> Elf check for viruses (or directory).
Q: I downloaded and put some sprite in a folder Daemons (it was written in the instructions of the elf). When rebooted the phone, it makes the peak-off and is not included! What should I do?
A: The easiest way out - take out the SIM card and connect the phone to the computer, turn on, and then, through your favorite explorer for the phone (for example, I use a plugin for Total Commandera), to remove this elf.
Q: And if there's no computer?
A: Unfortunately, if your computer, you are almost doomed! If you're lucky, you can try this: turn on the phone and when the splash screen appears, just briefly press the red button and run into the card explorer (not in my files!), In a folder Zbin, Daemons and try to remove this demon until it is completely load.
If the platform phone NewSgold, and all the elves are on the MMC card, then you are lucky :D just get the card, turn on the phone, after some time (quite a moment when you insert the card right away - the elves are loaded, and get pikoff), insert the card and remove vinovattsa.
And remember, never put the elves are not well tested in a folder Daemons! Elfov For normal operation, it is sufficient that there was only ExtD. All the other elves, you can run a simple joystick to them.
Q: Why when you start the phone crashes a message something like "Extd Parse Error !"???
A: It means a registered extension.cfg not valid values. Small error in the symbol may lead to such a post. It is also not allowed an extra space at the end.
Q: How do I edit extension.cfg if not at hand computer?
A: For these purposes there is an elf ExtManager (Sgold, NewSgold), with which you can edit extension.cfg.
Q: Is it possible to open unknown files with a few elves? For example in Windows operation "Open With"?
A: For these purposes there is an elf OpenWith (Sgold, NewSgold). To them vospolzovatsya, to associate the universal extension (which is the first in extension.cfg) with him. And set himself an elf in bcfg.
Q: How do I make a screenshot on the phone?
A: To do this, there is an elf DisplayShooter, which can be customized to bcfg hotkey for screenshots and a way for screenshots.
Q: What if I want to edit png image, and the company is not at hand. Is it possible to do this on my phone?
A: Yes, we must use the Java program PaintCAD from Rysya.
Q: To set some elves have to enter some key codes and the number of colors. How do I know these codes and numbers?
A: Read the FAQ, or take advantage of the elves. Both shows elves iWatch (only the last version!) Multitester (Sgold), only the scan codes - KeyTest (SGold).
At NewSgold can view the scan-key codes free patches and elves. To do this, go to the menu Developer (engineering menu, you must enter skey) - Component Test - C_couios - Keyboard Manager - Keycodes. Push the button and see what you need.
Here are some key codes.
Here the color table.
Q: How do I get a menu when minimized java-program?
A: Elf MenuD Native Menu is folded in Java. Sgold, NewSgold.
Q: At NewSgold, when folded java, when entering the main menu screen flashes. What is it?
A: Gluck main menu. Use the native menu bar, or elves MenuD. Sgold, NewSgold.
Q: Sometimes I do not need to download all the demons, but I'm tired of rename (move). There is a way to help manage downloads from a folder Daemons?
A: There is. For this is the elf PANDEMONIUM, with which you can choose what elves preloading the phone, and what does not. Sgold, NewSgold.
much remains to be appended :)
Re: Elves: What is and how to install them
Postby andRa4 » December 24th, 2010, 2:43 am
info yg sangat mnarik & mmbantu.
mas hendZ jago basa ruski tuwh,. :))
ho,..,oh d-atas translate-ny lum english banged, masih campur aduk. :D
Re: Elfs: What is and how to install them
Postby Hendz » April 19th, 2011, 2:30 pm
yiapz aq jg sk bgt ma ELF sih :). ga di Siemens ga di Moto, 2 2 na suka. coz ELF tuch "alat" yg bs brubah jd aplikasi, tp dkt bgt hubunganna ama prosesor2 ARM, jd jalannya kenceng bgt hampir nyamain aplikasi "nativ" na hp itu sndiri (kalo dikmbangkan & dg UI yg menarik) -- sayangna 2 model ELF qta bisa beda antara Sie & Moto wlwpun sama2 ARM-based... jd mgkin qta ga bs tukeran aplikasi :D
misal di Moto yg standar jaduL basis OS "p2k" qta pnya iTunes (app mediaplayer mp3 non nativ) running di ELF 1.5 & 2.0 -- jelas bakal ga jalan di Siemens..... mgkin krn perbedaan tipe ARM-na.
ok, nti aq bantu terjemahin teks na ke Bhs.Indo yg lebih ringkaz & cepet dipahamin :)
Postby ilham » April 19th, 2011, 4:32 pm
Hendz wrote:ok, nti aq bantu terjemahin teks na ke Bhs.Indo yg lebih ringkaz & cepet dipahamin :)
*mukangarep* :D
Postby aziz_gets » July 27th, 2011, 3:24 am
ilham wrote:Q: I noticed that some elves changed the weight on the X kb, frequent pikoffy, displays strange messages, etc. etc. What is it?
di cbn.narod.ru juga ada beberapa contoh virus elf nya mas...
barusan main ke situs database virus rusia vx.netlug.org
ternyata ada juga yg ngeshare koleksi virus elf nya sgold mas (dua biji)
ini link nya http://vx.netlux.org/vl.php?dir=Virus.SGold
disease,disease,disease my friends
for this whole world's in devil's hand
throw the key or you may die
.:;. keeper of the seven keys .:;.
aziz_gets
Postby ilham » July 27th, 2011, 4:45 am
Kalo ga salah di siemensmania juga ada elf virus, resmi, buat pembelajaran. ;)
Elf buat antivirus AVP ada juga, Elf buat seting BIOS HP ada juga, Elf buat maenin perintah2 DOS ada juga. :))
Postby TUFF Stough » November 1st, 2011, 4:17 pm
Sudah ada versi Elfloader terbaru (Elfloader v3).
Penjelasannya bikin gw pusing.
Bзменен elf loader, подробности тут
http://team-sc.ru/viewtopic.php?t=7252
\Отменяем Запрет использования каналов.vkp PatchID: 8467
PIML (Patch Idle Memory Leak).vkp PatchID: 8291
Как ставить, берем старый патч loadera( только лоадера библу не трогаем, отменяем не смотря на ругань V-klay (просто V-Klay затрет 0xFF), хотя моно и по верху просто куски от старого остануться, ставим этот патч, делаем тыц в тестовый эльф радуемся.В архиве тест эльф
[*] Улучшена совместимость со старыми эльфами
[+] Поддержка симлинков для либ, симлинк обычный текстовый файл содержащий только путь
[*] Поменян прицыпе вызова конструкторов, они теперь вызываются библиотекой libcrt, разрабам следует обновиться из темы разработки
[*] Исправлено 2 ошибки в освобождении либ
[+] Добавлено опциональная очистка либ при не использовании, вы можете выключить реалтайм освобождение тем самым увеличить скорость последующего запуска и освобождения эльфов.
[+] в свилиб вынесены 4 новых функций
0x2F6 getBaseEnviron - указатель на переменную окружения(требуется для либц)
0x2F7 dlerror - при ошибке открытия либы эта функция возвратит ошибку в текстовом виде
0x2F8 dlclean_cache - принудительная очистка кеша либ(если отключена реалтайм очистка)
0x2F9 SHARED_TOP - указатель на последнюю загруженую либу
dlcache.elf - по нажатию очистит кеш либ
Библиотеки можно взять тут:
http://st-hunter.ru/svn/trunk/libs/
Struktur dalam file attachment-nya juga cuma bbrp file elf aja:
dlcache.elf
elf_el.elf
elf_nsg.elf
elf_sg.elf
;S75v52
;ELFLoader_23.10.11
;ELFLoader_23.10.11
;(c) Z.Vova, Ganster
;Version: 3.0
;PatchID: 10222
;Details: http://patches.kibab.com/patches/details.php5?id=10222
;!There is a file attached to this patch, http://patches.kibab.com/cnt.php5?d=s75v52&f=ElfLoader_3_Z_Vova_Ganster_23_10_11.zip
#pragma enable old_equal_ff
;SWILIB_FUNC171,SWILIB_FUNC172
0x000745C4: AC8407A0988407A0
;SWILIB_FUNC19C
0x00074670: D18407A0
;SWILIB_FUNC1B8_1BB
0x000746E0: 28B1D7A82CB1D7A8E4B0D7A838B1D7A8
;SWILIB_FUNC1E9
0x000747A4: E0A307A0
;SWILIB_FUNC2EE_2F5
0x00074BB8: 608E07A031A207A0
0x00074BC0: F5A207A0B5A207A01C8B07A02C8B07A0
0x00074BD0: CC8B07A0408C07A0B18C07A02CA307A0
0x00074BE0: 44A307A038A307A0
;CODE,INITTAB,DATA_C,CONFIG_DATA_ID
0x00078000: 11FF2FE1130200EB0100A0E3F081BDE8
0x00078010: 10402DE90040A0E1A50A00EB000050E3
0x00078020: 1080BD180400A0E114C09FE500C09CE5
0x00078030: 3CFF2FE1040050E108C09FE500C09CE5
0x00078040: 1CFF2FE170AD07A074AD07A00F402DE9
0x00078050: 210200EB0070A0E10040A0E30F80BDE8
0x00078060: 005080E20F402DE91B0200EB0060A0E1
0x00078070: 0F80BDE80010A0E30F402DE9160200EB
0x00078080: 0050A0E10F80BDE80F402DE9120200EB
0x00078090: 0070A0E10050A0E30F80BDE800402DE9
0x000780A0: B80000EF0100A0E10080BDE81EFF2FE1
0x000780B0: 00109DE5200011E3192F8F020400000A
0x000780C0: C70050E3B200DE0014E08D0501E08EE2
0x000780D0: 51208FE250109FE5001091E5000051E3
0x000780E0: 48109F05803CC0E3400D53E30900008A
0x000780F0: 800C10E300402D090040FD0803C191E7
0x00078100: 04C08D150300001A01007CE320209F05
0x00078110: 04008D0514208DE50100BDE800F069E1
0x00078120: 0F80FDE81CFF2FE160470000E4B0D7A8
0x00078130: 004007A0908907A004E02DE500200FE1
0x00078140: 040000EF00100FE1C01081E301F021E1
0x00078150: 0000A0E10000A0E10000A0E17AFF17EE
0x00078160: 0000A0E10000A0E10000A0E1FAFFFF1A
0x00078170: 0000A0E39A0F07EE0000A0E10000A0E1
0x00078180: 0000A0E10000A0E10000A0E10000A0E1
0x00078190: 150F07EE0000A0E10000A0E10000A0E1
0x000781A0: 0000A0E10000A0E10000A0E102F021E1
0x000781B0: 04F09DE4F14F2DE904519FE504019FE5
0x000781C0: 04719FE504D04DE2056040E004009DE5
0x000781D0: 0040A0E30D30A0E18020A0E3801CA0E3
0x000781E0: 0A0000EF00A0A0E10480E0E108005AE1
0x000781F0: 1300000A0D30A0E10620A0E10710A0E1
0x00078200: 0B0000EF0090A0E10D00A0E101002DE9
0x00078210: 04308DE20220A0E30010A0E30A00A0E1
0x00078220: 0F0000EF00B0A0E104108DE20A00A0E1
0x00078230: 0D0000EF0B0059E104D08DE206005901
0x00078240: 1700000A0620A0E10510A0E10700A0E1
0x00078250: 1E0100EF04009DE50D30A0E1602FA0E3
0x00078260: 0210A0E3C01F81E30A0000EF00A0A0E1
0x00078270: 08005AE10F00000A0D30A0E10620A0E1
0x00078280: 0710A0E10C0000EF060050E10840A011
0x00078290: 0D10A0E10A00A0E10D0000EF000054E3
0x000782A0: 0200004A24009FE504109DE5001080E5
0x000782B0: 0400A0E1F68FBDE80840A0E10400A0E1
0x000782C0: F68FBDE818B107A06CB407A0F0ABD7A8
0x000782D0: E0B0D7A801C08FE21CFF2FE110B5054C
0x000782E0: 20001C30FFF766EF002802D52000FFF7
0x000782F0: 62EF10BD90AD07A07847C04600402DE9
0x00078300: 1D0100EF0080BDE800402DE9480100EF
0x00078310: 0080BDE8F0472DE90050A0E190909FE5
0x00078320: 0160A0E10270A0E10380A0E1620200EB
0x00078330: 0040B0E10400001A0910A0E10100A0E3
0x00078340: 480100EF0000E0E3F087BDE8980200EB
0x00078350: 00A0B0E10600001A101089E20100A0E3
0x00078360: 480100EF0400A0E19A0200EB0100E0E3
0x00078370: F087BDE86FFFFFEB0830A0E10720A0E1
0x00078380: 0610A0E10500A0E13AFF2FE1D900D4E5
0x00078390: 000050E3D0009405000050030200001A
0x000783A0: 000084E50400A0E18A0200EB0000A0E3
0x000783B0: F087BDE89CAE07A0D5FFFFEA08009FE5
0x000783C0: 0120A0E3101080E2D30100EAC0AE07A0
0x000783D0: 0020704710B5A0B0694614007E22A3DF
0x000783E0: 0023002221006846FFF7E6EF002801D0
0x000783F0: 002000E0012020B010BD000000402DE9
0x00078400: 14D04DE20D00A0E1530100EF000050E3
0x00078410: 1200000A04309DE508009DE5010053E3
0x00078420: 0600001A0C209DE5000052E30B00000A
0x00078430: 10109DE532FF2FE114D08DE20080BDE8
0x00078440: 01002DE904209DE5AE10A0E3DE1C81E3
0x00078450: 0900A0E3420C80E3000100EF04D08DE2
0x00078460: 14D08DE20080BDE800402DE91C209FE5
0x00078470: 1C109FE50000A0E301002DE98030A0E3
0x00078480: 0A00A0E3440C80E3050100EF0180BDE8
0x00078490: FC8307A0ECAE07A000402DE9460100EF
0x000784A0: 410100EF470100EF0080BDE800402DE9
0x000784B0: 04002DE90030A0E10A00A0E3440C80E3
0x000784C0: 0120A0E10110A0E3000100EF0180BDE8
0x000784D0: 10B514008847200015DF10BD10402DE9
0x000784E0: 0040A0E10A00A0E3440C80E3540100EF
0x000784F0: 930700EBD10100EB0C009FE5001090E5
0x00078500: 0400A0E11040BDE8BCFEFFEA64AD07A0
0x00078510: 94109FE510402DE948D04DE240DE4DE2
0x00078520: D20F8DE21A0000EFD20F8DE21B0000EF
0x00078530: 78109FE50040A0E1D20F8DE2170000EF
0x00078540: 0D20A0E1D21F8DE204008DE26B0000EF
0x00078550: 000050E30E00000AD20F8DE20010A0E3
0x00078560: 0010C4E7B9108DE2170000EF0030A0E3
0x00078570: 0020A0E30210A0E1D20F8DE264FFFFEB
0x00078580: 0D10A0E104008DE26C0000EF000050E3
0x00078590: F0FFFF1A0D10A0E104008DE26D0000EF
0x000785A0: 48D08DE240DE8DE21080BDE8E8ADD7A8
0x000785B0: 94AE07A010B58BB06A460024E44301A9
0x000785C0: 84DFA04201D1200000E002980BB010BD
0x000785D0: 38119FE5F0402DE934419FE578D04DE2
0x000785E0: 005094E504008DE21A0000EF000055E3
0x000785F0: 0300000A0000A0E3000084E50500A0E1
0x00078600: 150000EF04008DE2E9FFFFFA0050E0E3
0x00078610: 050050E13B00000AF8609FE5400C50E3
0x00078620: 0300000A2C1086E20100A0E3480100EF
0x00078630: 190000EA0D30A0E18020A0E3801CA0E3
0x00078640: 04008DE20A0000EF0070A0E1050057E1
0x00078650: 2C00000A400CA0E3140000EF0050A0E1
0x00078660: 0D30A0E1402CA0E30510A0E10700A0E1
0x00078670: 0B0000EF400C50E30D10A0E10700A0E1
0x00078680: 0700000A0D0000EF181086E20100A0E3
0x00078690: 480100EF0500A0E1150000EF78D08DE2
0x000786A0: F080BDE80D0000EF0070A0E30700E0E1
0x000786B0: 64109FE5072195E7000052E107219117
0x000786C0: 0000521107319517020053110500000A
0x000786D0: 0720A0E10610A0E144008DE2160000EF
0x000786E0: 44108DE2E8FFFFEA072195E7000052E1
0x000786F0: 0711910707118507017087E2400D57E3
0x00078700: EAFFFFBA005084E578D08DE2F080BDE8
0x00078710: 94AED7A8E4B0D7A850AE07A0004007A0
0x00078720: F0402DE988509FE588609FE588709FE5
0x00078730: 0040A0E14BFFFFEBE5FEFFEBA3FFFFEB
0x00078740: 780900EB1CFFFFEB0720A0E1101086E2
0x00078750: 0500A0E1160000EF0720A0E10610A0E1
0x00078760: 200085E2160000EF200086E28C0000EF
0x00078770: DF8000EF0000D0E5230050E30700000A
0x00078780: 38009FE5000090E5000050E30200000A
0x00078790: 2C009FE5710100EF000000EA5BFFFFEB
0x000787A0: 20009FE5001090E50400A0E113FEFFEB
0x000787B0: F080BDE8E8B0D7A808AE07A03CADD7A8
0x000787C0: 0CADD7A8108507A068AD07A0A82801D1
0x000787D0: 12487047AA2801D111487047AF2801D1
0x000787E0: 10487047B82801D10F487047BA2801D1
0x000787F0: 0E487047BF2801D10D487047B22801D1
0x00078800: 0C487047B32801D10B487047C02804DB
0x00078810: FF2802DCD42189004018704701040000
0x00078820: 04040000070400005104000054040000
0x00078830: 57040000060400005604000030B50400
0x00078840: 0D0004E0FFF7C2FF010028001CDF2078
0x00078850: 641C0028F6D130BD30402DE90040A0E1
0x00078860: 0250A0E1250EA0E10A0050E30600001A
0x00078870: 0010A0E30400A0E1260100EF0410A0E1
0x00078880: 0500A0E1ECFFFFFA3080BDE808109FE5
0x00078890: 0400A0E1240100EF3080BDE8ECAD07A0
0x000788A0: 30402DE90040A0E10F00A0E3250100EF
0x000788B0: 0050A0E1071F8FE2240100EF0020A0E3
0x000788C0: 0510A0E10400A0E1940000EF0500A0E1
0x000788D0: 290100EF3080BDE87478740010402DE9
0x000788E0: 84409FE5000094E5000050E30400001A
0x000788F0: 0400A0E3140000EF0010A0E3001080E5
0x00078900: 000084E5040080E21080BDE8F0412DE9
0x00078910: 54409FE5460100EF005094E52800A0E3
0x00078920: 006095E5900607E02C0087E2140000EF
0x00078930: 0080A0E1042087E20510A0E11E0100EF
0x00078940: 010086E2000088E50500A0E1150000EF
0x00078950: 008084E5470100EF0A00A0E3900601E0
0x00078960: 010188E0040080E2F081BDE828B1D7A8
0x00078970: 054A00B5914203D0044A1268904700BD
0x00078980: 3000FFF78EEF00BDD11D00006CAD07A0
0x00078990: 10402DE940409FE520D04DE20030A0E1
0x000789A0: 0020A0E1181084E20D00A0E1160000EF
0x000789B0: 0D00A0E1D85805EB020000EF0230A0E3
0x000789C0: 0220A0E30410A0E1FF00A0E3FF0C80E3
0x000789D0: 1E5905EB20D08DE21080BDE8C8AD07A0
0x000789E0: 0120F0E5010052E100005213FBFFFF1A
0x000789F0: 1EFF2FE1F44F2DE9B8829FE50040A0E1
0x00078A00: 0150A0E13D10A0E3F4FFFFEB00B098E5
0x00078A10: 046040E00070E0E30090A0E300A0A0E3
0x00078A20: 00005BE32C00001A02008AE20011A0E1
0x00078A30: 040098E5BA0000EF00B0B0E12200000A
0x00078A40: 001098E5040098E5000051E10200000A
0x00078A50: 0A21A0E10B00A0E11E0100EF00B088E5
0x00078A60: 0B00A0E1040088E50AB18BE000908BE5
0x00078A70: 04908BE50490A0E1000055E31000000A
0x00078A80: 0500A0E11B0000EF018080E2060088E0
0x00078A90: 010080E2140000EF0090B0E10A00000A
0x00078AA0: 0620A0E10410A0E11E0100EF090086E0
0x00078AB0: 3D10A0E30110C0E40820A0E10510A0E1
0x00078AC0: 1E0100EF00908BE50070A0E30700A0E1
0x00078AD0: F28FBDE801A08AE204B08BE200009BE5
0x00078AE0: 000050E3CFFFFF0A0620A0E10410A0E1
0x00078AF0: 150100EF000050E3F5FFFF1A00009BE5
0x00078B00: 0000D6E73D0050E3F1FFFF1A00009DE5
0x00078B10: 000050E3D6FFFF1AEAFFFFEA000051E3
0x00078B20: 00108F02B2FFFFEA0000000070402DE9
0x00078B30: 0040B0E10000D415000050130500000A
0x00078B40: 3D10A0E30400A0E1A4FFFFEB0010D0E5
0x00078B50: 3D0051E30100001A0000E0E37080BDE8
0x00078B60: 045040E04C019FE5006090E5000056E3
0x00078B70: 0700001A0000A0E37080BDE80600A0E1
0x00078B80: 041090E5001080E5041090E4000051E3
0x00078B90: FAFFFF1A000096E5000050E37080BD08
0x00078BA0: 0520A0E10410A0E1150100EF000050E3
0x00078BB0: 0300001A000096E50000D5E73D0050E3
0x00078BC0: EDFFFF0A046086E2F1FFFFEA70402DE9
0x00078BD0: 0040A0E1DC009FE5005090E5000055E3
0x00078BE0: 0100001A0000A0E37080BDE80400A0E1
0x00078BF0: 1B0000EF0060A0E1000000EA045085E2
0x00078C00: 001095E5000051E3F5FFFF0A0620A0E1
0x00078C10: 0400A0E11C0100EF000050E3F6FFFF1A
0x00078C20: 000095E50000D6E73D0050E3F2FFFF1A
0x00078C30: 000095E5000086E0010080E27080BDE8
0x00078C40: 70402DE96C409FE5040094E5000050E3
0x00078C50: 0100A0037080BD08000090E50060A0E3
0x00078C60: 0050A0E3000050E30500001A090000EA
0x00078C70: 0100A0E1150000EF040094E5065180E7
0x00078C80: 016086E2040094E5060180E0001090E5
0x00078C90: 000051E3F5FFFF1A040094E5150000EF
0x00078CA0: 045084E5005084E50000A0E37080BDE8
0x00078CB0: 014800687047000044AFD7A8F0402DE9
0x00078CC0: E8409FE534D04DE20430A0E18020A0E3
0x00078CD0: 801CA0E30A0000EF0050A0E10060E0E3
0x00078CE0: 060055E12E00000A0430A0E13420A0E3
0x00078CF0: 0D10A0E10B0000EF340050E32500001A
0x00078D00: 0D00A0E15C0000EB000050E32100001A
0x00078D10: E400A0E3140000EF0070B0E11D00000A
0x00078D20: 3420A0E30D10A0E1080087E21E0100EF
0x00078D30: 3C6087E5D45087E50000A0E3000087E5
0x00078D40: 0160A0E34060C7E5D00087E5C80087E5
0x00078D50: D800C7E5D900C7E5DC0087E5FF8000EF
0x00078D60: E00087E50700A0E1B70200EB000050E3
0x00078D70: 0600001AD860C7E50410A0E10500A0E1
0x00078D80: 0D0000EF0700A0E134D08DE2F080BDE8
0x00078D90: 0700A0E10F0000EB0410A0E10500A0E1
0x00078DA0: 0D0000EF0000A0E334D08DE2F080BDE8
0x00078DB0: 4CAFD7A8000050E31EFF2F013C1090E5
0x00078DC0: 202090E5000090E5001061E2000082E0
0x00078DD0: 000081E01EFF2FE130402DE90040B0E1
0x00078DE0: 0700A0033080BD08D800D4E5000050E3
0x00078DF0: 0B00000A0400A0E1470300EB080000EA
0x00078E00: 000095E5D30400EB000095E50010A0E3
0x00078E10: D40400EB040095E5D00084E50500A0E1
0x00078E20: 150000EFD05094E5000055E3F3FFFF1A
0x00078E30: C80094E5000050E30000000A150000EF
0x00078E40: 000094E5000050E30000000A150000EF
0x00078E50: 0400A0E1150000EF0000A0E33080BDE8
0x00078E60: 00402DE90010A0E108009FE5710100EF
0x00078E70: 0000A0E30080BDE8D88D07A030109FE5
0x00078E80: 10402DE90720A0E30040A0E11C0100EF
0x00078E90: 000050E30400A0131080BD18B201D4E1
0x00078EA0: 280050E30900A0131080BD180000A0E3
0x00078EB0: 1080BDE8A4B007A0F0402DE90040A0E1
0x00078EC0: 0250B0E11B00000AF06B9FE50020A0E3
0x00078ED0: 0600A0E101002DE93C0094E50630A0E1
0x00078EE0: 001041E0D40094E50F0000EF000050E3
0x00078EF0: 04D08DE20F00000A010085E2140000EF
0x00078F00: 0070A0E1D40094E50630A0E10520A0E1
0x00078F10: 0710A0E10B0000EF050050E10300001A
0x00078F20: 0000A0E30700C5E70700A0E1F080BDE8
0x00078F30: 0700A0E1150000EF0000A0E3F080BDE8
0x00078F40: B04F2DE962DF4DE20050A0E1000091E5
0x00078F50: 0280A0E10070A0E30040A0E3000050E3
0x00078F60: 0E00001A5C0095E5000050E31F00000A
0x00078F70: 3C0095E55C1095E5002095E5000060E2
0x00078F80: 021081E0010080E0180000EA002090E5
0x00078F90: 040090E5022185E0440082E5017087E2
0x00078FA0: 870181E0002090E5000052E3ECFFFF0A
0x00078FB0: 1F0052E3F8FFFFAA012052E20600000A
0x00078FC0: 0F2052E2F0FFFF1A000090E50120A0E3
0x00078FD0: 000185E0442080E5EFFFFFEA040090E5
0x00078FE0: 08208DE2040182E7014084E2EAFFFFEA
0x00078FF0: C00085E53C0095E5A01095E5002095E5
0x00079000: 000060E2021081E0010080E0C40085E5
0x00079010: 580095E5000050E30400000A3C0095E5
0x00079020: 581095E5000060E2021081E0010080E0
0x00079030: CC0085E54000D5E5020050E31800001A
0x00079040: 541095E50820A0E30500A0E199FFFFEB
0x00079050: 0070B0E10D00000A000097E5041097E5
0x00079060: 000081E00810A0E3002181E0541095E5
0x00079070: 0500A0E18FFFFFEBC80085E50700A0E1
0x00079080: 150000EFC80095E5000050E30400001A
0x00079090: 8C179FE50100A0E3480100EF0F00A0E3
0x000790A0: 8B0100EA0070A0E3020000EA041080E5
0x000790B0: D00085E5017087E2040057E11600002A
0x000790C0: CC1095E508008DE2070190E7019080E0
0x000790D0: 0510A0E10900A0E13F0300EB00A0B0E1
0x000790E0: 0400000A0800A0E3140000EF00A080E5
0x000790F0: D01095E5ECFFFFEA28179FE50920A0E1
0x00079100: 420F8DE2160000EF421F8DE20100A0E3
0x00079110: 7CFCFFEB0300A0E36D0100EA421F8DE2
0x00079120: 00108DE58C0095E5000050E36C01000A
0x00079130: 881095E50020A0E1040098E50070A0E3
0x00079140: 000081E0081098E50040A0E3011040E0
0x00079150: 0500A0E157FFFFEB0080B0E19700001A
0x00079160: 0500A0E11BFFFFEB580100EA0090A0E3
0x00079170: 04908DE50230A0E1FD0053E34B01008A
0x00079180: 029F8FE28330A0E1B39099E109F18FE0
0x00079190: 8A0047019C0047014701470147014701
0x000791A0: 47014701470147014701470147014701
0x000791B0: 47014701470147014701F70047017E00
0x000791C0: 47014701470147014701470147014701
0x000791D0: 47014701470147014701470147014701
0x000791E0: 47014701470147014701470147014701
0x000791F0: 47014701470147014701470147014701
0x00079200: 47014701470147014701470147014701
0x00079210: 47014701470147014701470147014701
0x00079220: 47014701470147014701470147014701
0x00079230: 47014701470147014701470147014701
0x00079240: 47014701470147014701470147014701
0x00079250: 47014701470147014701470147014701
0x00079260: 47014701470147014701470147014701
0x00079270: 47014701470147014701470147014701
0x00079280: 47014701470147014701470147014701
0x00079290: 47014701470147014701470147014701
0x000792A0: 47014701470147014701470147014701
0x000792B0: 47014701470147014701470147014701
0x000792C0: 47014701470147014701470147014701
0x000792D0: 47014701470147014701470147014701
0x000792E0: 47014701470147014701470147014701
0x000792F0: 47014701470147014701470147014701
0x00079300: 47014701470147014701470147014701
0x00079310: 47014701470147014701470147014701
0x00079320: 47014701470147014701470147014701
0x00079330: 47014701470147014701470147014701
0x00079340: 47014701470147014701470147014701
0x00079350: 47014701470147014701470147014701
0x00079360: 47014701470147014701470147014701
0x00079370: 47014701470147014701470147014701
0x00079380: 470147014701470147017E003C1095E5
0x00079390: 000090E5002095E5001061E2020080E0
0x000793A0: 009081E0000099E53C1095E5001061E2
0x000793B0: 021081E0000081E0000089E5017087E2
0x000793C0: 8C0095E5870150E1C300009A870188E0
0x000793D0: 041090E5FF2001E2C01095E5000051E3
0x000793E0: 61FFFF0A041090E5C03095E52114A0E1
0x000793F0: 011293E05CFFFF0A0C90D1E52992A0E1
0x00079400: 5AFFFFEA3C2095E5000090E5003095E5
0x00079410: 002062E2030080E0009082E0C00095E5
0x00079420: 000050E30400001AFC139FE5420F8DE2
0x00079430: 160000EF000095E5DEFFFFEACC0095E5
0x00079440: 000050E30100001AE0139FE5F6FFFFEA
0x00079450: 000091E5CC1095E501A080E00400DAE5
0x00079460: 000050E30000DA055F0050030100DA05
0x00079470: 5F0050030200DA05650050030300DA05
0x00079480: 780050030300001A0100A0E3D900C5E5
0x00079490: 005089E5C8FFFFEA0A10A0E10500A0E1
0x000794A0: CD0100EB0040B0E10B00001AD04095E5
0x000794B0: 0000A0E3030000EA000094E50A10A0E1
0x000794C0: F90100EB044094E5000054E30100000A
0x000794D0: 000050E3F7FFFF0A0040A0E1000054E3
0x000794E0: 2000001A04009DE5020050E31D00000A
0x000794F0: DC0095E5000050E30F00000A00B0A0E1
0x00079500: 070000EA4000DBE5020050E30A00001A
0x00079510: 0A10A0E10B00A0E1AF0100EBDCB09BE5
0x00079520: 0040A0E100005BE30100000A000054E3
0x00079530: F3FFFF0A000054E30A00001AF0129FE5
0x00079540: 0A20A0E1420F8DE2160000EF00109DE5
0x00079550: 0100A0E36BFBFFEB0800A0E1150000EF
0x00079560: 0B00A0E35A0000EA004089E592FFFFEA
0x00079570: C02095E5000052E30900001AB4129FE5
0x00079580: 420F8DE2160000EF00109DE50100A0E3
0x00079590: 5CFBFFEB0800A0E1150000EF0C00A0E3
0x000795A0: 4B0000EACC2095E5000052E30900001A
0x000795B0: 84129FE5420F8DE2160000EF00109DE5
0x000795C0: 0100A0E34FFBFFEB0800A0E1150000EF
0x000795D0: 0D00A0E33E0000EA3C2095E5000090E5
0x000795E0: 003095E5002062E2030080E0009082E0
0x000795F0: 000091E5CC2095E502A080E0040091E5
0x00079600: 030080E0000089E5040091E5000050E3
0x00079610: 69FFFF1AD0B095E5030000EA00009BE5
0x00079620: 0A10A0E1A00100EB04B09BE500005BE3
0x00079630: 0100000A000050E3F7FFFF0A000089E5
0x00079640: 000050E35CFFFF1A04009DE5020050E3
0x00079650: 59FFFF0A000054E31000001ADC0095E5
0x00079660: 000050E30F00000A0090A0E1070000EA
0x00079670: 4000D9E5020050E30A00001A0A10A0E1
0x00079680: 0900A0E1540100EBDC9099E50040A0E1
0x00079690: 000059E30100000A000054E3F3FFFF0A
0x000796A0: 000054E344FFFF1A90119FE5A3FFFFEA
0x000796B0: 8C119FE5420F8DE2160000EF00109DE5
0x000796C0: 0100A0E30FFBFFEB0800A0E1150000EF
0x000796D0: 0100A0E362DF8DE2B08FBDE80800A0E1
0x000796E0: 150000EF4C0095E5000050E34A00000A
0x000796F0: 0070A0E3040000EAC41095E5002095E5
0x00079700: 871191E7017087E2020081E74C0095E5
0x00079710: 870150E13F00009AC40095E5C01095E5
0x00079720: CC2095E5870180E0040090E52004A0E1
0x00079730: 001291E7024081E0C01095E5008281E0
0x00079740: 4000D5E5020050E38400950500005003
0x00079750: 0400001A0410A0E10500A0E11E0100EB
0x00079760: 000050E30A00001AD09095E50000A0E3
0x00079770: 030000EA000099E50410A0E14A0100EB
0x00079780: 049099E5000059E30100000A000050E3
0x00079790: F7FFFF0A000050E3D6FFFF1A0C10D8E5
0x000797A0: 2112A0E1020051E3D2FFFF0ADC1095E5
0x000797B0: 000051E30E00000A0180A0E1060000EA
0x000797C0: 4000D8E5020050E30900001A0410A0E1
0x000797D0: 0800A0E1000100EBDC8098E5000058E3
0x000797E0: 0100000A000050E3F4FFFF0A000050E3
0x000797F0: C0FFFF1A4C109FE50420A0E1420F8DE2
0x00079800: 160000EF00109DE50100A0E3BDFAFFEB
0x00079810: 0B00A0E3AEFFFFEA0000A0E362DF8DE2
0x00079820: B08FBDE804AF07A01CAF07A034AF07A0
0x00079830: 68AF07A09CAF07A0C0AF07A0F8AF07A0
0x00079840: 30B007A054B007A080B007A0F04F2DE9
0x00079850: 20D04DE20040A0E1B403D4E18002A0E1
0x00079860: 140000EF0050B0E18500000A24A094E5
0x00079870: 48829FE50090A0E30060A0E306B0A0E1
0x00079880: 0E0000EA000097E5010050E30800001A
0x00079890: 080097E53C1094E5010050E13C008435
0x000798A0: 080097E5141097E5000081E000005BE1
0x000798B0: 00B0A031B203D4E1019089E20AA080E0
0x000798C0: B403D4E10670E0E1000059E1180000AA
0x000798D0: 0800A0E101002DE9D40094E50830A0E1
0x000798E0: 0020A0E30A10A0E10F0000EF070050E1
0x000798F0: 04D08DE20E00000AD40094E5897285E0
0x00079900: 0830A0E12020A0E30710A0E10B0000EF
0x00079910: 200050E3DAFFFF0A000094E5150000EF
0x00079920: 006084E50500A0E1150000EF0E00A0E3
0x00079930: 540000EA3C0094E500004BE0040084E5
0x00079940: B413D4E1010059E15400001A010080E2
0x00079950: 140000EF000084E5000050E34F00000A
0x00079960: 041094E50090A0E3011081E262FAFFEB
0x00079970: 7C10A0E3440084E25FFAFFEB100000EA
0x00079980: 0C20A0E1000052E30C00000A04109DE5
0x00079990: 0400A0E147FDFFEB00A0B0E13100000A
0x000799A0: 0D20A0E10A10A0E10400A0E163FDFFEB
0x000799B0: 000050E32B00001A0A00A0E1150000EF
0x000799C0: 019089E2B403D4E1000059E12F0000AA
0x000799D0: 0D10A0E1890285E00C5CB0E80C5CA1E8
0x000799E0: 0C0090E80C0081E800009DE5010050E2
0x000799F0: 0200000A010050E2E0FFFF0AEFFFFFEA
0x00079A00: 00005CE3EDFFFF0A0800A0E101002DE9
0x00079A10: 08109DE5D40094E50830A0E10020A0E3
0x00079A20: 0F0000EF070050E104D08DE20F00000A
0x00079A30: 3C0094E508109DE500A094E510209DE5
0x00079A40: 0830A0E1000060E20A1081E0011080E0
0x00079A50: D40094E50B0000EF10109DE5010050E1
0x00079A60: D6FFFF0A010000EA0A00A0E1150000EF
0x00079A70: 000094E5150000EF006084E50500A0E1
0x00079A80: 150000EF0500A0E320D08DE2F08FBDE8
0x00079A90: 0500A0E1150000EF0000A0E3F9FFFFEA
0x00079AA0: 000094E5150000EF006084E50500A0E1
0x00079AB0: 150000EF0600A0E320D08DE2F08FBDE8
0x00079AC0: 4CAFD7A870402DE9AC1090E5000051E3
0x00079AD0: 7080BD08B01090E5A82090E52141A0E1
0x00079AE0: 3C1090E5000090E5001061E2000082E0
0x00079AF0: 005081E00060A0E3000054E30300001A
0x00079B00: 7080BDE8060195E7016086E230FF2FE1
0x00079B10: 040056E1FAFFFF3A7080BDE870402DE9
0x00079B20: AC1090E5000051E37080BD08B42090E5
0x00079B30: 0060A0E32241A0E13C2090E5000090E5
0x00079B40: 002062E2000081E0005082E0000054E3
0x00079B50: 0300001A7080BDE8060195E7016086E2
0x00079B60: 30FF2FE1040056E1FAFFFF3A7080BDE8
0x00079B70: 00402DE90030A0E38020A0E3801CA0E3
0x00079B80: 0A0000EF010070E30300000A0010A0E3
0x00079B90: 0D0000EF0100A0E30080BDE80000A0E3
0x00079BA0: 0080BDE80020D0E50010A0E3000052E3
0x00079BB0: 0700000A0120D0E4011282E0F02411E2
0x00079BC0: 222C2210011022100020D0E5000052E3
0x00079BD0: F7FFFF1A0100A0E11EFF2FE1F0472DE9
0x00079BE0: 0040A0E1000054E3C80094150150A0E1
0x00079BF0: 000050130000A003F087BD080500A0E1
0x00079C00: E7FFFFEBC81094E50070A0E3002091E5
0x00079C10: 088081E2021181E0086081E20010A0E1
0x00079C20: 0200A0E11CF9FFEB008198E7000000EA
0x00079C30: 088196E7000058E31900000AC00094E5
0x00079C40: 080280E004A090E5002090E50C90D0E5
0x00079C50: 00005AE3BE00D01100005013F3FFFF0A
0x00079C60: 0F0009E2020050E3F0FFFF8ACC0094E5
0x00079C70: 0510A0E1000082E0190000EF000050E3
0x00079C80: EAFFFF1A000094E52912A0E100008AE0
0x00079C90: 011051E2F087BD08011051E20070A001
0x00079CA0: E2FFFFEA0700A0E1F087BDE8000050E3
0x00079CB0: 1EFF2F01400090E5C7FFFFEAF0412DE9
0x00079CC0: 0040A0E10150A0E10260A0E1000054E3
0x00079CD0: 000055130100000A000056E30100005A
0x00079CE0: 0000A0E3F081BDE83B10A0E3180000EF
0x00079CF0: 0470A0E10080A0E3040000EA017090E2
0x00079D00: 0A00000A3B10A0E30700A0E1180000EF
0x00079D10: 0610A0E1016041E2000051E300005713
0x00079D20: 0400000A000050E3F3FFFF1A0070A0E3
0x00079D30: 0000A0E3F5FFFFEA000050E30400001A
0x00079D40: 000057E3E5FFFF0A0400A0E11B0000EF
0x00079D50: 040080E0074040E00420A0E10710A0E1
0x00079D60: 0500A0E11E0100EF0580C4E70500A0E1
0x00079D70: F081BDE8F0402DE954709FE50040A0E1
0x00079D80: 50009FE50060A0E38FFBFFEB0050A0E1
0x00079D90: 000000EA016086E20620A0E1841087E2
0x00079DA0: 0500A0E1C4FFFFEB000050E3F080BD08
0x00079DB0: 0410A0E1840087E2170000EF840087E2
0x00079DC0: 6AFFFFEB000050E3F1FFFF0A840087E2
0x00079DD0: F080BDE850AFD7A8ACB007A0F24F2DE9
0x00079DE0: 34D04DE20050B0E10000D51500005013
0x00079DF0: 3E00000AA8659FE55C10A0E3004096E5
0x00079E00: 0500A0E1170100EF000050E301708012
0x00079E10: 0570A001000000EA084094E5000054E3
0x00079E20: 0E00000A008094E50710A0E10800A0E1
0x00079E30: 190000EF000050E3F6FFFF1A440098E5
0x00079E40: 0220A0E3010080E2440088E50010A0E3
0x00079E50: 040086E2BB0000EF0800A0E1240000EA
0x00079E60: 0100D5E53A0050E30580A0010A00000A
0x00079E70: 0500A0E1BEFFFFEB0080B0E10600001A
0x00079E80: 1A0000EA060088E08490C0E50710A0E1
0x00079E90: 0400A0E10D0000EF848086E2A8729FE5
0x00079EA0: 8020A0E30730A0E1801CA0E30800A0E1
0x00079EB0: 0A0000EF0040A0E10080E0E3080050E1
0x00079EC0: 0100001A84129FE5060000EA0730A0E1
0x00079ED0: 3420A0E30D10A0E10B0000EF010050E3
0x00079EE0: 050000AA68129FE5040086E21A0000EF
0x00079EF0: 0000A0E338D08DE2F08FBDE80090A0E3
0x00079F00: 340050E30300003A0D00A0E1DAFBFFEB
0x00079F10: 000050E32300000A0700A0E101002DE9
0x00079F20: 0730A0E10220A0E30010A0E30400A0E1
0x00079F30: 0F0000EF0080A0E1400F58E304D08DE2
0x00079F40: 140000AA010058E3120000BA0700A0E1
0x00079F50: 01002DE90730A0E10020A0E30210A0E1
0x00079F60: 0400A0E10F0000EF0730A0E10820A0E1
0x00079F70: 841086E20400A0E10B0000EF080050E1
0x00079F80: 04D08DE2BEFFFF0A0710A0E10400A0E1
0x00079F90: 0D0000EFD5FFFFEAB4119FE5040086E2
0x00079FA0: 1A0000EFF7FFFFEAA0B19FE5E400A0E3
0x00079FB0: 140000EF00A0B0E10100001A2C108BE2
0x00079FC0: C8FFFFEA3420A0E30D10A0E108008AE2
0x00079FD0: 1E0100EF3C808AE5D4408AE50200A0E3
0x00079FE0: 4000CAE5D0908AE5D890CAE534009DE5
0x00079FF0: DC008AE5FF8000EFE0008AE50A00A0E1
0x0007A000: 11FEFFEB000050E30800000A1C108BE2
0x0007A010: 040086E21A0000EF0710A0E10400A0E1
0x0007A020: 0D0000EF0A00A0E16AFBFFEBAFFFFFEA
0x0007A030: 0710A0E10400A0E10D0000EF4C00A0E3
0x0007A040: 140000EF0040B0E10200001A0A00A0E1
0x0007A050: 60FBFFEBD8FFFFEA40A084E50170A0E3
0x0007A060: 447084E57C009AE5000050E30B00001A
0x0007A070: 0100D5E53A0050E30400001A5C10A0E3
0x0007A080: 0500A0E1170100EF000050E30100001A
0x0007A090: 0510A0E1050000EA011080E2010000EA
0x0007A0A0: CC109AE5011080E0000051E33C108B02
0x0007A0B0: 0400A0E11A0000EF0C00A0E3140000EF
0x0007A0C0: 000050E30600001A2C108BE2040086E2
0x0007A0D0: 1A0000EF0010A0E30400A0E1210000EB
0x0007A0E0: 82FFFFEA004080E5049080E5480084E5
0x0007A0F0: 001096E5000051E30400811500109615
0x0007A100: 081080E5000086E50A00A0E16CFEFFEB
0x0007A110: D870CAE574109AE5000051E30600000A
0x0007A120: 3C209AE500309AE50500A0E1002062E2
0x0007A130: 031081E0011082E031FF2FE1B490C6E1
0x0007A140: 0400A0E138D08DE2F08FBDE84CAFD7A8
0x0007A150: BCB007A0D8B007A0441090E5011041E2
0x0007A160: 441080E51EFF2FE130402DE90040B0E1
0x0007A170: 0700A0033080BD08440094E5010050E3
0x0007A180: 270000AAA0009FE5000090E5000050E3
0x0007A190: 000051032200000A480094E5405094E5
0x0007A1A0: 000050E31A00000A780095E5000050E3
0x0007A1B0: 0500000A3C1095E5002095E5001061E2
0x0007A1C0: 020080E0000081E030FF2FE1D0219FE5
0x0007A1D0: 480094E5003092E5041090E5030050E1
0x0007A1E0: 0300001A083093E5000053E308309015
0x0007A1F0: 003082E5000051E30820901508208115
0x0007A200: 081090E5000051E30420901504208115
0x0007A210: 150000EF0500A0E1EEFAFFEB0400A0E1
0x0007A220: 150000EF0000A0E33080BDE840AFD7A8
0x0007A230: F1B50024E443002801D1200038E03A4D
0x0007A240: 686800280BD1802040006860800014DF
0x0007A250: 28600028F1D069688900FEF74DF86968
0x0007A260: 002600E0761C28688E4205DAB2008258
0x0007A270: 002AF7D1A64211D140318900BADF0700
0x0007A280: 01D1200014E06E6880214900B0003818
0x0007A290: FEF732F868682F604030686000980021
0x0007A2A0: FFF79CED0028C8D02A68B10050503000
0x0007A2B0: 01B0F0BD10B50021002801D5012200E0
0x0007A2C0: 0022194B5C68641E944201DA002010BD
0x0007A2D0: 1A68800010180268002A09D014000160
0x0007A2E0: 2000FFF73AEF00212000FFF73EEF10BD
0x0007A2F0: 002010BD10B5002801D5012200E00022
0x0007A300: 094B5C68641E944201DA002010BD1A68
0x0007A310: 800010180268002A03D01000FFF7C6EC
0x0007A320: 10BD002010BD0000D8B0D7A800009FE5
0x0007A330: 1EFF2FE154AFD7A864009FE5000090E5
0x0007A340: 1EFF2FE1F0402DE954409FE5005094E5
0x0007A350: 000055E30000E003F080BD080560A0E1
0x0007A360: 0070A0E3000096E5441090E5010051E3
0x0007A370: 020000AA0110A0E37AFFFFEB017087E2
0x0007A380: 000094E5000055E1086096050050A011
0x0007A390: 0060A011000056E3F1FFFF1A0700A0E1
0x0007A3A0: F080BDE850AFD7A800B5080014DF00BD
0x0007A3B0: 00B5080015DF00BD30402DE904D04DE2
0x0007A3C0: 0140A0E10250A0E15E0100EF0D30A0E1
0x0007A3D0: 0520A0E10410A0E10B0000EF3180BDE8
0x0007A3E0: F04F2DE928D04DE20150A0E10060A0E3
0x0007A3F0: 00608DE50C608DE514308DE28020A0E3
0x0007A400: 801CA0E30A0000EF0040A0E1010070E3
0x0007A410: 3201000A0080A0E30670A0E10690A0E1
0x0007A420: 14308DE20820A0E320108DE20B0000EF
0x0007A430: 080050E32001001A0810A0E320008DE2
0x0007A440: B20100EF000050E31B01000A20059FE5
0x0007A450: 01002DE91C059FE501002DE90000A0E3
0x0007A460: 01002DE90030A0E10020A0E10010A0E1
0x0007A470: 04059FE5A80100EF0C008DE5000050E3
0x0007A480: 0CD08DE20C01000A560100EF0C008DE5
0x0007A490: 000050E30400001A0020A0E30210A0E1
0x0007A4A0: 0D00A0E1570100EF030100EA00009DE5
0x0007A4B0: 620100EF000050E30020A0130C108D12
0x0007A4C0: F6FFFF1AB4249FE500009DE50410A0E1
0x0007A4D0: A90100EF00009DE50810A0E3580100EF
0x0007A4E0: 0C109DE500009DE5590100EF0000A0E3
0x0007A4F0: 01002DE901002DE901002DE91C008DE2
0x0007A500: 01002DE928008DE201002DE920109DE5
0x0007A510: 1C308DE214009DE518208DE25A0100EF
0x0007A520: 000055E314D08DE20500001A10009DE5
0x0007A530: 000050E348049F15FF50A00300009015
0x0007A540: 0150801218009DE5080050E3010000AA
0x0007A550: 00009DE5D60100EF00009DE50C109DE5
0x0007A560: 1020A0E3AC0100EF000050E30100000A
0x0007A570: 00009DE5AD0100EF18009DE5100050E3
0x0007A580: 0100001A00009DE5AF0100EF18009DE5
0x0007A590: 080050E3010000AA00009DE5B00100EF
0x0007A5A0: 10009DE5030050E30100001A00009DE5
0x0007A5B0: AB0100EF10009DE5040050E300005013
0x0007A5C0: 0100001A00009DE5B10100EF00009DE5
0x0007A5D0: 0120A0E3FF10A0E3AE0100EF0C109DE5
0x0007A5E0: 00009DE5AA0100EF00009DE50C109DE5
0x0007A5F0: 5F0100EF140000EF0080A0E10800A0E3
0x0007A600: 140000EF1C008DE50090A0E104009DE5
0x0007A610: FF0055E32F00001A070080E2A051A0E1
0x0007A620: 08009DE595000BE00B00A0E1140000EF
0x0007A630: 0070A0E10B10A0E11D0100EF08009DE5
0x0007A640: 07A0A0E100B0A0E3000050E31400001A
0x0007A650: 0100A0E3890000EA001188E00020D1E5
0x0007A660: 000052E30120D105000052030210D105
0x0007A670: 000051030400001AA0118AE00020D1E5
0x0007A680: 07C000E2332C82E10020C1E5010080E2
0x0007A690: 04109DE5010050E1EEFFFF3A0AA085E0
0x0007A6A0: 01B08BE208009DE500005BE1E7FFFF2A
0x0007A6B0: 00009DE50020A0E30810A0E1600100EF
0x0007A6C0: 04109DE50600A0E1000051E38030A0E3
0x0007A6D0: EEFFFF1AF0FFFFEA08109DE5A4A29FE5
0x0007A6E0: 910000E0015055E20400000A015055E2
0x0007A6F0: 2C00000A015055E25700000A600000EA
0x0007A700: 140000EF0070A0E108009DE50750A0E1
0x0007A710: 00B0A0E3000050E30200001A0500A0E3
0x0007A720: 560000EA01B08BE208009DE500005BE1
0x0007A730: F9FFFF2A00009DE50020A0E30810A0E1
0x0007A740: 600100EF04109DE50600A0E1000051E3
0x0007A750: 1CC0A0E30900001AF1FFFFEA0020D1E5
0x0007A760: 0130D1E50210D1E5E02002E2A3310CE0
0x0007A770: 022083E1211382E10110C5E4010080E2
0x0007A780: 04109DE5010050E1E5FFFF2A00309AE5
0x0007A790: 001188E00320D1E5030052E1EEFFFF2A
0x0007A7A0: C010A0E3F3FFFFEA8000A0E1140000EF
0x0007A7B0: 0070A0E108009DE50750A0E100B0A0E3
0x0007A7C0: 000050E30200001A0800A0E32B0000EA
0x0007A7D0: 01B08BE208009DE500005BE1F9FFFF2A
0x0007A7E0: 00009DE50020A0E30810A0E1600100EF
0x0007A7F0: 04109DE50600A0E1000051E37ECEA0E3
0x0007A800: 0B00001AF1FFFFEA0020D1E5F83CA0E3
0x0007A810: 022403E00130D1E50210D1E583310CE0
0x0007A820: 022083E1A111A0E1021081E1B210C5E0
0x0007A830: 010080E204109DE5010050E1E3FFFF2A
0x0007A840: 00309AE5001188E00320D1E5030052E1
0x0007A850: ECFFFF2AE01CA0E3F3FFFFEA0001A0E1
0x0007A860: 140000EF0070A0E108009DE50750A0E1
0x0007A870: 00A0A0E3000050E32900001A0A00A0E3
0x0007A880: B200C9E104009DE50000C9E508009DE5
0x0007A890: 0100C9E5047089E50C109DE500009DE5
0x0007A8A0: 5D0100EF0020A0E30C108DE20D00A0E1
0x0007A8B0: 570100EF000057E32500001A0800A0E1
0x0007A8C0: 150000EF0700A0E1150000EF0900A0E1
0x0007A8D0: 150000EF14108DE20400A0E10D0000EF
0x0007A8E0: 0000A0E328D08DE2F08FBDE8001188E0
0x0007A8F0: 0220D1E5010080E20120C5E40120D1E5
0x0007A900: 0120C5E40020D1E50120C5E40310D1E5
0x0007A910: 0110C5E404109DE5010050E1F2FFFF3A
0x0007A920: 01A08AE208009DE500005AE1D2FFFF2A
0x0007A930: 00009DE50020A0E30810A0E1600100EF
0x0007A940: 04109DE50600A0E1000051E3F0FFFF1A
0x0007A950: F2FFFFEA0800A0E1150000EF14108DE2
0x0007A960: 0400A0E10D0000EF1C009DE528D08DE2
0x0007A970: F08FBDE8B1A307A0A9A307A004B107A0
0x0007A980: B8A307A07CACD7A81CACD7A80A78002A
0x0007A990: 0BD00A78412A02DB5B2A00DA2032491C
0x0007A9A0: 02700A78401C002AF3D1002101707047
0x0007A9B0: 70402DE90040A0E10150A0E10F60A0E3
0x0007A9C0: 0A0055E30900003A0510A0E10A00A0E3
0x0007A9D0: B1F5FFEB066280E10510A0E10A00A0E3
0x0007A9E0: BC0000EF0050A0E10A0055E3F5FFFF2A
0x0007A9F0: 300085E20100C4E4020000EA300085E2
0x0007AA00: 0100C4E42662A0E10F5006E20A0055E3
0x0007AA10: F9FFFF3A2E00A0E30100C4E47000A0E3
0x0007AA20: 0100C4E46E00A0E30100C4E46700A0E3
0x0007AA30: 0100C4E40000A0E30000C4E57080BDE8
0x0007AA40: F0402DE9D8529FE50040A0E10560A0E1
0x0007AA50: 460100EF0070A0E3000000EA0670A0E1
0x0007AA60: 006096E5000056E30E00000A040096E5
0x0007AA70: 0410A0E1190000EF000050E3F6FFFF1A
0x0007AA80: 000057E30400000A000096E5000087E5
0x0007AA90: 000095E5000086E5006085E5470100EF
0x0007AAA0: 080096E5F080BDE8470100EF0000A0E3
0x0007AAB0: F080BDE8F0472DE964429FE540DF4DE2
0x0007AAC0: 0050A0E1250EA0E10A0050E30E00001A
0x0007AAD0: 0510A0E10D00A0E1ABFFFFFA0D00A0E1
0x0007AAE0: D6FFFFEB0050B0E10000000A4D0000EA
0x0007AAF0: 0010A0E30D00A0E138FEFFEB0050B0E1
0x0007AB00: 5500001A0C029FE5470000EA460100EF
0x0007AB10: 080094E5000000EA000090E5000050E3
0x0007AB20: 0800000A041090E5050051E1F9FFFF1A
0x0007AB30: 086090E5000056E3F6FFFF0A470100EF
0x0007AB40: 0600A0E1380000EA470100EF040094E5
0x0007AB50: 000050E36D00000A2000A0E34E0C80E3
0x0007AB60: 000055E11A00002A8000A0E3A8A19FE5
0x0007AB70: 031005E28110A0E13091A0E1040094E5
0x0007AB80: A960A0E1257180E00080D7E5080019E1
0x0007AB90: 1100000A080016E10D00000A0A10A0E1
0x0007ABA0: 0D00A0E178FFFFFA0510A0E17FFFFFEB
0x0007ABB0: 0D00A0E1A1FFFFEB0050B0E11900001A
0x0007ABC0: 0010A0E30D00A0E104FEFFEB0050A0E1
0x0007ABD0: 210000EA0000A0E3130000EA460100EF
0x0007ABE0: 0000D7E5000089E10000C7E5470100EF
0x0007ABF0: 0A10A0E10D00A0E163FFFFFA0510A0E1
0x0007AC00: 6AFFFFEB0D00A0E18CFFFFEB0050B0E1
0x0007AC10: 0700000A460100EF0000D7E5000086E1
0x0007AC20: 0000C7E5470100EF0500A0E140DF8DE2
0x0007AC30: F087BDE80010A0E30D00A0E1E7FDFFEB
0x0007AC40: 0050B0E1E2FFFF0A460100EF0000D7E5
0x0007AC50: 000086E10000C7E5470100EF0C00A0E3
0x0007AC60: 140000EF0060A0E10D00A0E11B0000EF
0x0007AC70: 010080E2140000EF040086E50D10A0E1
0x0007AC80: 1A0000EF085086E5460100EF000094E5
0x0007AC90: 0050A0E30080A0E3000086E5006084E5
0x0007ACA0: 0400A0E1004094E5000054E30100001A
0x0007ACB0: 470100EF140000EA60109FE5018088E2
0x0007ACC0: 001091E5080051E1F4FFFF2A005080E5
0x0007ACD0: 470100EF080094E5000050E30300000A
0x0007ACE0: 040090E5150000EF080094E5150000EF
0x0007ACF0: 040094E5150000EF0400A0E1004094E5
0x0007AD00: 150000EF000054E3F1FFFF1A080096E5
0x0007AD10: 40DF8DE2F087BDE80CB107A03CADD7A8
0x0007AD20: 4CACD7A82CB1D7A830402DE92C509FE5
0x0007AD30: 8840A0E3040095E54C4D84E3000050E3
0x0007AD40: 0200001A0400A0E1140000EF040085E5
0x0007AD50: 040095E50410A0E11D0100EF3080BDE8
0x0007AD60: 2CB1D7A893F12FA079EF2FA0F37C97A0
0x0007AD70: B080A2A0936197A054030000F0ABD7A8
0x0007AD80: 18B107A09C01000044AFD7A844AFD7A8
0x0007AD90: 303A5C5A42696E5C6574635C456C6650
0x0007ADA0: 61636B2E6263666700000000343A5C5A
0x0007ADB0: 42696E5C6574635C456C665061636B2E
0x0007ADC0: 626366670000000001014E6F2066756E
0x0007ADD0: 6374696F6E20696E206C6962A1000000
0x0007ADE0: 2564282530335829000000007C25647C
0x0007ADF0: 00000000416C744F70656E004F70656E
0x0007AE00: 00000000656C66002573656C665F6269
0x0007AE10: 672E706E670000002573656C665F736D
0x0007AE20: 616C6C2E706E670004AE07A055000000
0x0007AE30: FF089D05F4AE07A0FCAE07A0FCAD07A0
0x0007AE40: F4AD07A0FBC0FF7FD58307A000000000
0x0007AE50: 46756E6374696F6E20256420636F6E66
0x0007AE60: 6C6963742100000043616E2774207265
0x0007AE70: 6164206C6962726172792100496C6C65
0x0007AE80: 67616C206C6962726172792073697A65
0x0007AE90: 210000002A2E656C6600000043616E74
0x0007AEA0: 206F70656E20656C6600000043616E74
0x0007AEB0: 20666F756E6420656E74727900000000
0x0007AEC0: 4C445F4C4942524152595F5041544800
0x0007AED0: 303A5C5A42696E5C6C69625C3B343A5C
0x0007AEE0: 5A42696E5C6C69625C3B000048454C50
0x0007AEF0: 45520000E8B0D7A80000000008B1D7A8
0x0007AF00: 000000004572726F72206C6F6164696E
0x0007AF10: 672068617368746162000000CDE520EC
0x0007AF20: EEE3F320E7E0E3F0F3E7E8F2FC202573
0x0007AF30: 2100000052656C6F636174696F6E2052
0x0007AF40: 5F41524D5F41425333322063616E6E6F
0x0007AF50: 742072756E20776974686F7574207379
0x0007AF60: 6D7461620A00000052656C6F63617469
0x0007AF70: 6F6E20525F41524D5F41425333322063
0x0007AF80: 616E6E6F742072756E20776974686F75
0x0007AF90: 74207374727461620A0000005B315D20
0x0007AFA0: 556E646566696E656420726566657265
0x0007AFB0: 6E636520746F20602573270A00000000
0x0007AFC0: 52656C6F636174696F6E20525F41524D
0x0007AFD0: 5F474C4F425F4441542063616E6E6F74
0x0007AFE0: 2072756E20776974686F75742073796D
0x0007AFF0: 7461620A0000000052656C6F63617469
0x0007B000: 6F6E20525F41524D5F474C4F425F4441
0x0007B010: 542063616E6E6F742072756E20776974
0x0007B020: 686F7574207374727461620A00000000
0x0007B030: 5B325D20556E646566696E6564207265
0x0007B040: 666572656E636520746F20602573270A
0x0007B050: 00000000466174616C206572726F7221
0x0007B060: 20556E6B6E6F776E2074797065207265
0x0007B070: 6C6F636174696F6E2027256427210A00
0x0007B080: 5B335D20556E646566696E6564207265
0x0007B090: 666572656E636520746F20602573270A
0x0007B0A0: 000000007F454C46010101004C445F4C
0x0007B0B0: 4942524152595F50415448006E6F2073
0x0007B0C0: 7563682066696C65206F722064697265
0x0007B0D0: 63746F72790000006261642066696C65
0x0007B0E0: 20747970650000006F7574206F66206D
0x0007B0F0: 656D6F72790000004572726F72204C69
0x0007B100: 62210000312E322E3500000000000100
0x0007B110: 14B107A0FF00000001000000416C7068
0x0007B120: 612D6368616E207468726573686F6C64
0x0007B130: 00000000000000000000000000000000
0x0007B140: FF0000008000000001000000504E4720
0x0007B150: 63616368652073697A65000000000000
0x0007B160: 00000000000000000000000014000000
0x0007B170: C8000000320000000500000044656661
0x0007B180: 756C74206269742D6465707468000000
0x0007B190: 00000000000000000000000000000000
0x0007B1A0: 03000000020000003820626974730000
0x0007B1B0: 00000000000000000000000000000000
0x0007B1C0: 00000000000000003136206269747300
0x0007B1D0: 00000000000000000000000000000000
0x0007B1E0: 0000000000000000323420626974732B
0x0007B1F0: 616C7068610000000000000000000000
0x0007B200: 00000000000000000B0000004C6F6164
0x0007B210: 206461656D6F6E20696E207375627072
0x0007B220: 6F630000000000000000000000000000
0x0007B230: 020000000100000002000000496D6167
0x0007B240: 6520666F6C6465722077617900000000
0x0007B250: 00000000000000000000000000000000
0x0007B260: 7F000000343A5C5A42696E5C696D675C
0x0007B270: 00000000000000000000000000000000
0x0007B280: 00000000000000000000000000000000
0x0007B290: 00000000000000000000000000000000
0x0007B2A0: 00000000000000000000000000000000
0x0007B2B0: 00000000000000000000000000000000
0x0007B2C0: 00000000000000000000000000000000
0x0007B2D0: 00000000000000000000000000000000
0x0007B2E0: 00000000020000004461656D6F6E7320
0x0007B2F0: 666F6C64657220776179000000000000
0x0007B300: 0000000000000000000000007F000000
0x0007B310: 343A5C5A42696E5C4461656D6F6E735C
0x0007B320: 00000000000000000000000000000000
0x0007B330: 00000000000000000000000000000000
0x0007B340: 00000000000000000000000000000000
0x0007B350: 00000000000000000000000000000000
0x0007B360: 00000000000000000000000000000000
0x0007B370: 00000000000000000000000000000000
0x0007B380: 00000000000000000000000000000000
0x0007B390: 020000007377692E626C696220776179
0x0007B3A0: 00000000000000000000000000000000
0x0007B3B0: 00000000000000007F000000303A5C5A
0x0007B3C0: 42696E5C7377692E626C696200000000
0x0007B3D0: 00000000000000000000000000000000
0x0007B3E0: 00000000000000000000000000000000
0x0007B3F0: 00000000000000000000000000000000
0x0007B400: 00000000000000000000000000000000
0x0007B410: 00000000000000000000000000000000
0x0007B420: 00000000000000000000000000000000
0x0007B430: 0000000000000000000000000B000000
0x0007B440: 5265616C74696D65206C696220636163
0x0007B450: 686520636C65616E6572000000000000
0x0007B460: 000000000200000001000000
;PATCH_ONCREATE
0x0042E514: 208707A0
;PATCH_ONCLOSE
0x0042E528: DC8407A0
;PATCH_EXT2_JUMPERS
0x004CEFB0: 0CF09FE50CF09FE50CF09FE50CF09FE5
0x004CEFC0: 0CF09FE54C8007A0608007A0748007A0
0x004CEFD0: 888007A00C8907A0
;PATCH_EXT2_R5R7
0x004D442C: FAF7C6ED
;PATCH_EXT2_CLUST2
0x004D444C: 3800
;PATCH_EXT2_R5R1
0x004D452A: FAF746ED
;PATCH_EXT2_R4R7
0x004D46C2: FAF776EC
;PATCH_EXT2_CLUST1
0x004D46EE: 3800
;PATCH_EXT2_IMPL
0x004D470C: FAF758EC
0x004D4710: C046C046C046C046C046C046C046C046
0x004D4720: C046
;PATCH_EXT2_R6R5
0x004D47DC: FAF7EAEB
;PATCH_NO_BROWSE_TXT
0x0054BE3A: 3030
;PATCH_ENABLE_ALTOPEN
0x005A0506: 0028
;PATCH_SHOWMSG_BLF
0x0065E4CC: 718907A0
;PATCH_ESI1
0x00906E4C: 08F09FE5
;PATCH_ESI2
0x00906E5C: 048007A0
;PATCH_GET_PIT,PATCH_GET_PITJ
0x00976188: 00490847108007A0
;FSWI_PATCH2
0x013A5328: B08007A0
;FSWI_PATCH1
0x013A5414: F4F01FE5
 ; Needed function
+0074000
03FC: 0xA0074000   ;  FF: unsigned int AddrLibrary()
+0
#pragma disable old_equal_ff
;------------------------- end -------------------------
Ada yang bisa ngasih pencerahan bagaimana cara pengaplikasiannya?
Postby ilham » November 2nd, 2011, 1:19 am
Sudah final toh? Terakhir kali masih beta saya lihat di googlecode.
Ntar deh saya coba pas di depan PC.
Postby ilham » November 7th, 2011, 1:12 pm
Belum sempat ke PC :D
Tapi sempat baca-baca di HP, itu EP3 yang tersebut di atas kayaknya belum resmi, belum ada di perk maupun di kibab. Cara kerjanya antara lain:
Dia (EP3) loadingnya ikut di bootcore.
Punya shared library (jadi ELF-ELF tidak usah punya library sendiri, cukup pakai yang shared, menghemat space).
Kompatibel ke aplikasi ELF sebelumnya.
DLCACHE.ELF gunanya untuk cleaning cache yang digunakan (Masih belum ngerti).
Berlaku juga untuk SGold, NSGold, ELKA.
Postby TUFF Stough » November 7th, 2011, 1:27 pm
Untuk S75fw52 sudah steady di Kibab.
Return to ELF
